• 14.11.2026, 21:59
Flop Ysh
[solved] Aquasuite and USB hub
Freitag, 2. Juli 2021, 17:59
Hello
I have Thermaltake H200 PLUS Hub USB. The huib is working well since the corsair rgb controller is plugged in for months and I have also several wireless receiver plugged in.
But I've added the NEXT VARIO and the D5 NEXT and both are not recognized at all when I launch the aquasuite setup. The screen of the Vario is not even on, while the pump is correctly working and displaying thanks to the sata cable.
Is it a know issue? or should it work? ?(
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Flop Ysh« (5. Juli 2021, 00:29)
Samstag, 3. Juli 2021, 03:19
Have you tried connecting the vision & d5 next directly to the motherboard to see if the issue is with the hub?
Flop Ysh
Samstag, 3. Juli 2021, 14:00
No but I've foreseen this:
I've not much room left to redo the cable routing and to plug them... I would love to find a software based solution first
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Flop Ysh« (3. Juli 2021, 23:53)
Flop Ysh
Montag, 5. Juli 2021, 00:29
I'm so dumb
:P
I was too tired I plugged them the wrong way... just all
now it's fine
Sorry and thx for the message
