• 13.11.2026, 20:16
TBear086
AMBIENTpx Stopped Working
Freitag, 9. Juli 2021, 13:48
So I just got AMBIENTpx setup on the backside of my monitor this past weekend. I have the LED strips linked to a Farbwerk 360 unit that I also located on the back of the monitor. Initially I plugged it all in and fired it up and it worked great during gaming and watching movies, however since yesterday's bootup I haven't been able to get AMBIENTpx to function for me.
Sometimes when I start the PC AMBIENTpx will work for all of maybe 5 seconds then the LEDs switch to a dim white light and stay that way. Other times the dim white is all I get with no signs of life from AMBIENTpx.
When I try any other mode besides AMBIENTpx I am able to successfully use and control my LED strips. I'm really failing to understand why AMBIENTpx stopped working, it's like my video data cannot be analyzed (yes I did check the box in aquasuit for analyze video data).
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »TBear086« (9. Juli 2021, 13:49)
TBear086
Samstag, 10. Juli 2021, 16:16
So I solved my problem:
The issue was that AquaComputerServiceHelper.exe was not running, I have no idea how that happened but it's fixed now and my AMBIENTpx is back up and running!
Jacob
Mittwoch, 14. Juli 2021, 17:29
Yes it is
I have encountered a similar situation
But it happens when the service is started
I restarted the system and it returned to normal :)
