• 09.10.2026, 21:34
WinstonWoof
Aquasuite service does not restart on Wake from Sleep
Samstag, 24. Juli 2021, 11:18
Have to open up Services and restart it manually
Is this a known issue and is there an automated workaround?
W10 Version 21H1(OS Build 19043.1110)
Issue seen on Aquasuite X.40 AND X.41
Ivoto
Dienstag, 27. Juli 2021, 07:28
For me is the same when the pc gets back from sleep it looses the cpu and gpu sensor.
Dienstag, 27. Juli 2021, 08:01
After the resume from sleep the service need 10..20 seconds to resume the hardware monitoring.
Are the other monitoring sensors (mainboard, network..) working?
WinstonWoof
Dienstag, 27. Juli 2021, 08:10
That may be the design however I can leave it for 2 minutes plus and it does not resume automatically.
NB in my case none of the sensors are showing any data even though in Services.msc (as well as in AquaSuite) the Aqua Computer Service shows as Running.
I have to restart the service to get any data
WinstonWoof
Sonntag, 1. August 2021, 13:24
@sebastian
Have resolved the issue by creating a Task scheduler entry (set to run with highest priveledges) as per https://sumtips.com/how-to/run-program-w…leep-hibernate/
Which calls a restart.bat file saved into the aquasuite folder
net stop "Aqua Computer Service" && net start "Aqua Computer Service"
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »WinstonWoof« (4. August 2021, 21:43)
