• 05.10.2026, 09:20
thilan29
PWM not working on Aquaero 5LT
Dienstag, 10. August 2021, 15:51
I have an Aquaero 5LT which I had been using to control 6 PWM fans (connected to active splitter).
After I accidentally upgraded Aquasuite to X.42 (no license), it seems I can no longer get PWM to work. I've tried resetting the 5LT, uninstalling and reinstalling X.4 (I only have a license up to that version), but no luck. It was fully functional before the update to X.42, so I'm assuming this is a software issue, but I'm at wits end!! I've tried every conceivable setting in the fan section, to no avail.
The splitter (Phobya 8-way PWM splitter) and cable are functional because I connected it to my motherboard and PWM works fine. If I connect a single PWM fan to the 5LT, PWM only works at 0% or 100%...nothing in between. I'm using a set point controller to keep the water temp at 35C to control the fans...this was functioning as-expected before. Firmware on the 5LT says it's up-to-date (2104).
Any thoughts? Thanks in advance for any assistance.
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »thilan29« (10. August 2021, 17:35)
thilan29
Dienstag, 10. August 2021, 23:04
Tried a hard reset of the device (with an uninstall of Aquasuite first), reloaded newest firmware, reinstalled Aquasuite X.4, and still no dice. PWM is not working.
thilan29
Freitag, 13. August 2021, 00:44
Anyone? Any thoughts?
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »thilan29« (13. August 2021, 01:28)
