• 12.11.2026, 17:31
Karsten Ravneng
Filterremoval D5NEXT
Montag, 16. August 2021, 13:13
Hello, good people.
Maybe a stupid question, but how do you remove the filter in the bottom of the res? Just pull it out, or do I need to disassemble the pump?
Thanks in advance :)
Flop Ysh
Montag, 23. August 2021, 01:01
Hi there
It's very easy
The walls of the reservoir can be unscrewed from the casing, then the filter is now available to be just popped out. So if you were using the regular inlet/outlet of the ULTITUBE, you just have to flush the water, no need to the unscrew threads or remove tubes. Done that to clean the filter for the first filling of the loop
Karsten Ravneng
Montag, 23. August 2021, 04:36
Thank you, good chap :)
