• 06.10.2026, 00:40
ngc
Water cooling on a moving/rotating platform
Dienstag, 28. September 2021, 16:51
Hi all,
Apologies if this is the wrong place to ask, but I have an unusual (or so I think) problem to solve.
I need to liquid cool a camera on that's on a moving platform (a large telescope), that will move in pretty much all orientations, upside down etc.
I am currently using something called an Oasis UC160 liquid chiller to cool the camera in the lab. It provides a steady temperature to camera and works very well in a stationary position. However, it will not function on this moving platform since the reservoir cannot operate in any other position than upright.
Does anybody know if an alternative reservoir exists which I could use in conjunction with my liquid chiller?
(the telescope is a bit too big to place the chiller/reservoir on the ground, tubing would get in a mess :wacko: )
Thanks!
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »ngc« (28. September 2021, 16:57)
Dienstag, 28. September 2021, 17:06
Is it possible to use some kind of gimbal for the chiller and attach it to the telescope?
That would be the only thing that comes to mind.
ngc
Dienstag, 28. September 2021, 17:26
It's a tempting avenue to explore. I have had a google before, and found maybe the ZHIYUN Crane 3S as having the power/size to handle what I would need. But I have no idea how reliable or programmable such a gimbal would be.
Tempted to make one myself, but I don't think I have the time for that.
Dienstag, 28. September 2021, 18:57
You need a reservoir with an flexible membrane for compensation of expansion. The loop needs to be filled without any air using a vacuum pump to evacuate the reservoir and then fill it with fluid.
ngc
Mittwoch, 29. September 2021, 12:59
That sounds like a good idea. I will investigate the options online. If you know of any good expansion tanks/vacuum pumps suitable for a system dealing with <0.5L of liquid please let me know.
Tasky
Donnerstag, 30. September 2021, 00:20
The Leakshield can do that, right...?
Not sure if you'd need to connect it to a USB header for full functionality (if only just the onec for setup), but could be worth a look.
