• 21.11.2026, 15:49
Jacob
How to connect AQUAERO XT and LT?
Freitag, 1. Oktober 2021, 11:02
Greetings
I was new
I installed a set of aquaero XT6
Because 18 fans need to be connected, I installed aquaero LT again
I connect these two devices via aquabus but I can’t see LT in aquasuite
Because my aquabus is connected to a lot of devices
calitemp x4
D5 NEXT x1
High flow NEXT x1
Farbwerk 360 x1
The above devices can be seen in the aquabus searcher
But I can't find LT
Can you tell me what to do?
Thank you in advance for your assistance.
Jacob
Freitag, 1. Oktober 2021, 11:04
I found the error
My USB cable is plugged in reverse :P
Freitag, 1. Oktober 2021, 20:31
Easy mistake to make with the 5-pin USB cables. Glad you got it working.
Jacob
Montag, 4. Oktober 2021, 23:00
I am also very happy to find the problem
Thanks for your reply :)
