• 12.11.2026, 17:51
chon
Dual Loop System and High Flow 2
Freitag, 8. Oktober 2021, 21:47
I am going to run a dual loop setup, where the CPU and GPU will have its own pump and reservoir. I currently have a Quadro and 1 x High Flow 2 sensor. I thought about picking up a second one, however, my Quadro only has 1 flow sensor input.
Is there any way to make this work, or another controller I can purchase from Aquacomputer?
Freitag, 8. Oktober 2021, 22:45
The aquaero 6 is the only controller with two flow inputs.
Two options available for the 2nd loop are:
  1. a second quadro/high flow 2 combination
  2. or a high flow next connected over USB
Remayz
Freitag, 8. Oktober 2021, 23:41
if it helps, the Farbwerk360 also has a flow sensor input, if you have more need for RGB channels
