• 07.10.2026, 19:15
markappelman
Using a Quadro/Octo for external cooling of laptop
Sonntag, 21. November 2021, 22:33
I am setting up external cooling for my laptop as it runs hot during summer and gaming. Planning to install a couple of 80mm fans below (towards the intake) and one on the side to support the outflow. Currently I have a 12V/60W adapter which supports the PWM-fans.
Found the Octo/Quadro and it seems a good solution to manage the fans, but I see its power source is a Molex-connector. Does the board require the 5V from
the molex, or does it just use the 12V? (and take the 5V from the USB as well). I plan to use a external->internal USB-connector for connectivity (and power). I couldn't find this in the manual or on the forum.
Also, will the 60W be enough for this solution. I read the board can adjust for 100W, but my fans together only require 1A in total.
Montag, 22. November 2021, 07:18
The quadro and octo require 5V and 12V.
Montag, 22. November 2021, 11:10
You could use one of THESE. If you are in the USA it will require a power cord like THIS.
markappelman
Dienstag, 23. November 2021, 12:44
Thanks for the quick response and suggestions.
