• 30.09.2026, 02:47
Grouchat
D5 Next led bug
Freitag, 26. November 2021, 17:22
Since a while the led strip of my D5 Next doesn't work well, see the picture:
All leds are on in aquasuite X.47 but only the first one works. I checked one by one.
I tested :
shutdown the computer and I unpluged the psu
shutdown the computer and I unpluged the psu then I unpluged and repluged the control unit
result : no effect
So any ideas ?
Thanks
Dieser Beitrag wurde bereits 6 mal editiert, zuletzt von »Grouchat« (26. November 2021, 17:26)
rlm
Donnerstag, 16. Dezember 2021, 21:58
Hi, it's an hardware problem; aquacomputer know this.
email to support from this.
you have two options :
return the pump from repair
or
aquacomputer send you a new piece and you change the piece... (it's easy)
