• 13.07.2026, 06:18
htxwn
Leakshield d5 100 unit with a flat reservoir?
Sonntag, 28. November 2021, 19:42
I have an O11xl and a standard flt120 from Ek I was planning to use on the rear fan mount, but is this compatible in the system with leakshield ultitube d5? I want more water capacity but not sure if using that config will be ok with leakshield.
Montag, 29. November 2021, 11:55
I don't believe the LEAKSHIELD cares, or knows, what is in the loop, as long as the loop meets the pressure requirements.
htxwn
Montag, 29. November 2021, 15:41
I figured but just making sure because of placement. The leakshield will be top of the ultitube and basically level with the flt120 on the other side. I’m hoping it removes all the air from the other res but does the ultitube need to be higher up?
Remayz
Montag, 29. November 2021, 16:48
not really.
the water won't "fall" in the ultitube, overtopping the leakshield if there's no air intake to allow the water to fall back.
If you add an air intake in the loop to ease draining, just don't open it with the leakshield powered on :) but you usually drain the loop with the power off if you're not mad so it should be okay :p
Montag, 29. November 2021, 16:59
The leakshield's purpose is not to remove air in your loop, it only reduces pressure in the loop.
If you have a leak, the leakshield actually causes air to be introduced into the loop.
Deaeration will need to be performed as normal.
Hufeisen
Montag, 29. November 2021, 17:39
This can be a major problem when you have two reservoirs.
Depending on the location of the leak, the introduced air can empty the reservoir without the Leakshield, and pulling all water into the reservoir with the Leakshield attached.
If the Reservoir with the Leakshield cannot take in all the water from the other reservoir and overflows, the Leakshield cannot prevent the leak and is useless.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Hufeisen« (29. November 2021, 17:42)
htxwn
Dienstag, 30. November 2021, 20:24
Right this is my concern. How would you prevent this?
Remayz
Dienstag, 30. November 2021, 22:21
get a standalone leakshield and put it on top of the loop? :)
htxwn
Dienstag, 30. November 2021, 23:45
No offense meant but Leakshield is awesome... when used with the ultitube. The standalone leaves a lot to be desired from what I understand.
Basic outlook is that Leakshield needs to be higher than the other reservoir then?
Remayz
Mittwoch, 1. Dezember 2021, 00:01
no offense taken :)
My idea was that, if the FLT is the highest reservoir, i would connect the standalone leak shield on its fill port.
It would work the same as on top of an ultitube as long as the inlet has access to air in the reservoir (not overfilled).
htxwn
Mittwoch, 1. Dezember 2021, 00:08
no offense taken :)
Guess I just need to make sure that the top of the tube is well above the other FLT120 on the rear mount.
Hufeisen
Mittwoch, 1. Dezember 2021, 17:35
There is only one way to make the Leakshield work with two reservoirs. You must connect both reservoirs to the Leakshield at the same time.
Run a Hose from both reservoir tops, and use a T-Connector to connect both Hoses to the Leakshield.
All other solutions have their problems, and may not work reliable during an emergency.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Hufeisen« (1. Dezember 2021, 17:48)
htxwn
Donnerstag, 2. Dezember 2021, 04:40
Ok so maybe I don’t understand what you mean.
This is an ultitube d5 with leakshield on top. How do you connect reservoir tops? It’s not possible to connect anything to leakshield top on ultitube.
Hufeisen
Donnerstag, 2. Dezember 2021, 22:47
Then you have to accept the fact that your leakshield can only protect 50% of your loop from a possible leak, if the pump is offline.
If the pump is running, that changes a lot, and the protection ranges from 10% of your loop to 90% of your loop, depending on flow direction and component placement.
To archieve a good protection rate, the water flow direction and component placement have to be the following: Reservoir with Leakshield --> Reservoir without Leakshield --> Cooling Components (Waterblock/Radiators) --> Reservoir with Leakshield.
With this, only the distance between the two reservoirs is not protected from a possible leak.
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Hufeisen« (2. Dezember 2021, 22:54)
Jacob
RE: Leakshield d5 100 unit with a flat reservoir?
Sonntag, 5. Dezember 2021, 18:47
Don't understand why you insist on using a flat water block?
Is it to install two D5 NEXT? If there is only one Ultituibe Pro, the problem is much simpler!
My system is also very complicated
I have an AMS with a D5 NEXT attached,
But I only install one Ultitube PRO 200. :)
[/url]IMG_E2052 by Jacob Tien, 於 Flickr[/img]
