• 29.11.2026, 11:19
cptninc
Why would a High Flow Next stop measuring flow rate?
Donnerstag, 2. Dezember 2021, 23:05
I have a High Flow Next which was working great. I changed the routing of my loop and now the meter reads 0 for flow although the temp and conductivity both read correctly. I have confirmed that there is flow visually.
What can I do to try and fix this?
cptninc
Mittwoch, 8. Dezember 2021, 16:47
I guess I will just add this to my pile of Aquacomputer gear that is waiting for me to RMA it.
Freitag, 10. Dezember 2021, 11:37
Try an email to support@aqua-computer.de
turgin
Donnerstag, 23. Dezember 2021, 22:39
I am now seeing a similar problem with mine. It works fine most of the time but if I load the system it will drop to zero flow and raise the alarm. Sometimes it starts working again on its own after a few minutes but other times it takes a reboot. I will be sending an email to support.
Edit to add that even a shutdown, including removing the power cord, has not recovered it this time.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »turgin« (23. Dezember 2021, 23:01)
cptninc
Mittwoch, 26. Januar 2022, 20:20
I've done absolutely nothing to address this problem, but yesterday the sensor started working again. This is weird since I hadn't even rebooted the system since my original post on it.
