• 12.11.2026, 20:45
knacker
EK gpu/cpu block rgb control
Samstag, 25. Dezember 2021, 13:29
Hi all
I currently have octo with D5 next pump, high flow and ultitubes leds connected and working good. I have EK cpu & gpu block and currently use Asus Aura rgb software but keep having issues with it crashing. Is it possible to use either the Octo or daisy chain the D5 next to control the blocks
Thx
Tasky
Sonntag, 26. Dezember 2021, 10:53
So long as your EK kit has 3-pin 5v connectors on their RGB leads (which most do these days, I believe), you can get little RGBpx adapters that will connect an Aquacomputer lead to the EK kit and it will run just like any other RGBpx kit.
https://shop.aquacomputer.de/product_inf…roducts_id=3829
knacker
Sonntag, 26. Dezember 2021, 11:25
Thanks for the reply- I wasn’t aware of these so have ordered a couple to try
