• 30.11.2026, 23:27
Chaos666
Can't see hwinfo64 or aida64 sensors in aquasuite
Dienstag, 28. Dezember 2021, 00:59
hi
i used to use older version of aquasuite (2018-12?) but then stopped using my aquaero 5 lt for a while. Now i updated it to the newest X.47 but i cannot se sensors from aida or hwinfo
is there something i am missing?
mditsch
Dienstag, 28. Dezember 2021, 06:13
have you updatet Aida and HW info to later or best latest versions? If you*re uisng HW info with the latest version, you have for working to activate shared Memory support in HW info settings.
Chaos666
Dienstag, 28. Dezember 2021, 13:01
hi
HWiNFO64 v7.16-4650
Aida64 v6.50.5800
i can see aquasuite sensors in hwinfo ... i cannot see hwinfo sensors in aquasuite
where is that shared memory support option?
edit: i found the shared memory support option .. and it works..
updated aida to the newest 6.60 and still can see anything.. but hwinfo also seems to be very limited
thanks
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Chaos666« (28. Dezember 2021, 13:16)
