• 12.11.2026, 22:24
z00mantwo
Aquasuite won't auto start.
Dienstag, 25. Januar 2022, 16:31
Any ideas on getting Aquasuite to auto start on reboot? I have the check box "Start aquasuite with Windows" checked and I did do it while running as administrator.
Dienstag, 25. Januar 2022, 18:14
Have you tried extending the 'Start delay' by a few seconds?
z00mantwo
Dienstag, 25. Januar 2022, 20:28
Tried 10, 20, and 30 second startup delays. Still does not auto start. ?(
Mittwoch, 26. Januar 2022, 02:44
Have you checked the Task Scheduler for anything unusual? {task_scheduler.jpg}
z00mantwo
Donnerstag, 27. Januar 2022, 03:59
I did get it to work. Had to go into Task Scheduler. Edit the "aquasuite autostart" task and check the "Run with highest privileges" under the "General" tab. :)
z00mantwo
Sonntag, 6. Februar 2022, 04:16
Issue came back randomly. Had to go back in to the Task Scheduler again and make the change. Something turned off the "Run with highest privileges" under the "General" tab.
