• 05.10.2026, 18:42
z00mantwo
Feature Request: Select high flow NEXT under flow sensor in OCTO
Donnerstag, 27. Januar 2022, 06:17
Feature Request: Use high flow NEXT under flow sensor in OCTO when the high flow NEXT is connected with the 3 pin wire 53295 to the OCTO. OCTO gets signal from high flow NEXT when connected, but can not scale the signal correctly to get the right flow rate. :)
Donnerstag, 27. Januar 2022, 07:32
You have to select "High Flow". High flow and High flow next has the same calibration values.
z00mantwo
Donnerstag, 27. Januar 2022, 13:53
When I try and select "Aqua Computer high flow (53068 )" as the "Sensor Type" I get a value of 29.89 l/m on the OCTO. The high flow NEXT says the flow is 2.57 l/m. Using another standalone flow meter I get a 2.6 l/m value so the high flow NEXT appears to be correct and accurate.
Donnerstag, 27. Januar 2022, 15:59
