• 16.11.2026, 03:23
Top_Nurse
Where's the firmware?
Samstag, 5. Februar 2022, 09:25
I added the Aquasuite update service so I could see what's up. I found two notes in the change logs. One that I could get firmware updates with the Windows updates and another that said I should look in the firmware folder. Can't find anything!
What I currently show in latest version of Aquasuite:
Tubemeter: Firmware 107
Aquastream XT: Firmware 1017
So what to do? I currently do not have any Aquaeros installed.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Top_Nurse« (5. Februar 2022, 09:28)
Samstag, 5. Februar 2022, 12:48
Your best path may be to communicate direct with support: support@aqua-computer.de
Montag, 7. Februar 2022, 07:23
you cant update the firmware from this devices.
Top_Nurse
Montag, 7. Februar 2022, 10:13
If I hook back up my version 4 Aquaero can I then update the firmware? Currently I have both the Aquastream and Tubemeter connected to the internal motherboard USB ports.
Montag, 7. Februar 2022, 10:23
no, you have the lastest firmware for your devices.
Top_Nurse
Dienstag, 8. Februar 2022, 07:05
Thanks Sebastian for the info!
