• 21.11.2026, 01:51
mattlach
Will the Aquaero 6 work properly in a USB 1.1 port?
Freitag, 11. Februar 2022, 22:38
Hey everyone!
I am considering using an Aquaero 6 in an unconventional manner, aiding me in cooling a system controlled by an old embedded computer (can't be upgraded due to need for old controller interfaces)
The system supports a max of USB 1.1.
The Aquaero 5 and Aquaero 6 both use USB2 interfaces.
Will they function if connected to a USB 1.1 interface, or do they require all of the bandwidth and power provided by a USB2 port?
If not, I see that the Aquaero 4 used to use USB 1.1. If I can get my hands on an old Aquaero 4, is it still supported on current Aquasuite software?
Thanks for any input.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »mattlach« (11. Februar 2022, 22:40)
Samstag, 12. Februar 2022, 05:23
PWM ports on the aquaero allow you to control PWM pumps & fans directly, and it has 2 flow sensor input ports, and 8 temperature sensor ports.
It is possible to setup the aquaero, without USB, using the on-screen buttons, or an infrared controller, but that can be a pain in the butt.
You may want to setup the aquaero, and peripheral gear, while connected to a windows 8 (or higher) system, and then move the gear to your existing system to run autonomously.
There are some peripherals that have the aquabus available, which does not require USB 2.0
I believe the aquaero 4 is retired and is not supported by current software.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (12. Februar 2022, 05:35)
