• 30.11.2026, 23:29
andsoitgoes
Disabled "global profiles" and "offset" but STILL have a indicator in the taskbar, how can I turn this off, also aquasuite won't start at windows launch, is there an easy fix?
Dienstag, 12. April 2022, 07:51
The title says mostly everything, I can't seem to find a way to remove this.
I've disabled the global profiles, yet the icon still shows. Same with the Offset, even if I've removed it - still shows up.
Also, is there any easy way to boot Aquasuite so it runs with windows startup?
Thanks.
Edit: was able to restart the service and solve the offset issue, profiles still there, still super annoying.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »andsoitgoes« (12. April 2022, 07:54)
Dienstag, 12. April 2022, 13:39
