• 02.10.2026, 14:16
schiaffo88
High Flow Meter switchoff problem
Dienstag, 12. April 2022, 10:33
Hello,
although I have the auto shutdown Flag via USB, the FlowMeter does not turn off with the PC, activating the Alarm Signal below 30L / h ...
How can I fix the USB signal shutdown problem?
»schiaffo88« hat folgende Bilder angehängt:
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »schiaffo88« (12. April 2022, 10:36)
Shojiro
Dienstag, 12. April 2022, 16:58
Do you have the cable that connects from the High Flow NEXT to the motherboard power switch header as seen here?
As per the high flow next manual, it says this under the signal connector:.
Utilization as alarm output - The header can be connected to the power switch header of the motherboard us-ing an additional specialized cable (53216, not included in delivery)
I definitely read the first post wrong, sorry. Ignore the above
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Shojiro« (12. April 2022, 20:02)
Hufeisen
Dienstag, 12. April 2022, 18:18
Maybe you need to select "disable alarm detection" in the Aquasuite software.
»Hufeisen« hat folgende Datei angehängt:
