• 02.10.2026, 17:19
Norton
D5 Next pump - not working?
Montag, 18. April 2022, 17:47
Hi all, just finished my new build with remote rad and d5 next pump/Res however on the first power up it's giving me nothing other than red lighting. The pump won't turn and the screen isn't working.
Any ideas?
Thank you in advance.
Montag, 18. April 2022, 18:00
Is the power cable plugged in correctly and are the electronics firmly seated on the pump?
Simply disconnect and reconnect both.
Is the D5 in the computer or on the external radiator?
If it is external, with what kind of power supply?
Norton
Montag, 18. April 2022, 18:11
Yup everything is seated correctly. Like I say, the RGB ring lights up red but there's no other signs of life. It is external and powered by a phobya molex PSU. Its wattage rating should exceed the power draw of the pump and three fans I intended to use (Inc start up power draw).
Montag, 18. April 2022, 18:17
Then test if it works on the power supply of your computer, if it doesn't work there either and you have already disconnected the electronics it is probably a case for the support.
Norton
Montag, 18. April 2022, 18:34
Thank you.
Tried my PC's PSU, now I have a spinning pump but still no screen and now no lit up RGB ring as well ..
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Norton« (18. April 2022, 18:49)
Dienstag, 19. April 2022, 11:51
The external Phobya power supplies have repeatedly been blamed for being extremely bad.
There is a chance, that it damaged your pump.
Norton
Dienstag, 19. April 2022, 12:18
Bugger. Time to buy another then I guess.
Dienstag, 19. April 2022, 14:28
Maybe this is enough, the pump itself works.
https://shop.aquacomputer.de/product_inf…roducts_id=4044
