• 08.10.2026, 20:41
tiggerlator
high flow LT on a vision
Freitag, 22. April 2022, 13:26
Just a quick question.
If i connect a high flow LT sensor to the flow sensor connector on a Vision will it just work and give a flow reading without having to do anything else? Just got a replacement for the faulty one, and really would like it to work so can someone give me a run through of the settings i need on the Vision and on aquasuite for it, thx
I7 12700k - Asus Rog Strix z690-A WiFi D4 - TEAM GROUP 2X16GB DDR4 3600C16 - MSI RTX 3080 GAMING X TRIO 10GB - Crucial P5 Pro 500GB M.2 NVMe Gen4x4 - WD SN850 1TB M.2 NVME Gen4x4 x2- SanDisk 2TB SSD PLUS 2.5" - Corsair RM850X - Lian Li o11D XL - EK 360mm PE - EK 360mm XE - EK supremacy classic - Generic (GPU) - Ultitube 150 D5 - dell s2721dgfa 27" nano IPS 165hz Custom corsair PSU cables
tiggerlator
Freitag, 22. April 2022, 15:12
Well connected it to a fan header on my board and blew through it and got a reading xRPM. Now connected to the Vision and nothing, In settings on the vision there is a page for temp but not for flow sensor, why not. It seems the vision is not picking the flow sensor up. For now i guess i will have to just connect it to a fan header at least i will have an indication of flow.
Disappointed really.
tiggerlator
Freitag, 22. April 2022, 16:46
I have removed the Vision the LT sensor and uninstalled the aquasuite program.
I will still buy and use AQ reservoirs and pumps/fittings but nothing electronic and nothing that uses the AQ program.
