• 07.10.2026, 00:38
Undesirable
EasyAntiCheat Game Security Violation [AquaComputerService.exe]
Sonntag, 22. Mai 2022, 22:29
The game Lost Ark keeps randomly kicking me out to the desktop several times per day with this message:
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Undesirable« (22. Mai 2022, 22:32)
Montag, 23. Mai 2022, 00:48
You may want to contact support @ easy anti-cheat. It sounds like they are pinging a false positive on aquacomputerservice.exe
Montag, 23. Mai 2022, 06:56
Have you tried disabling audio and video analysis under aquasuite -> audio and video?
Undesirable
Donnerstag, 26. Mai 2022, 03:12
Thanks, I've turned this option off and I'll see what happens.
Undesirable
Freitag, 27. Mai 2022, 14:51
Unfortunately the Security Violation error happened again whilst those options were turned off.
Freitag, 27. Mai 2022, 14:56
Then try the other hardware monitor settings, first I would turn off the GPU and CPU monitoring and see what happens.
I don't have the problem, but also only use the monitoring of the HDD/SSD, the rest of the values come from HWInfo64.
Freitag, 27. Mai 2022, 17:47
I would also contact support at easy anti-cheat... they need to make an exception for whatever triggers them on AquaComputerService.exe
Undesirable
Samstag, 28. Mai 2022, 03:47
Thanks, I might just do that InfoSeeker & Tabenhaucher.
All I have switched on is CPU & GPU monitoring right now. It could be happening less frequently, not sure yet.
Samstag, 28. Mai 2022, 10:01
These are exactly the two values that most likely cause the problems.
Undesirable
Montag, 30. Mai 2022, 01:53
Probably, but those are also the two values that I need monitored most! :S
