• 11.10.2026, 07:04
lingyu
ULTITUBE D5 NEXT Alarm and Water pump fails to operate
Samstag, 18. Juni 2022, 12:21
Today, I turned on the computer and found that D5 NEXT reported an error. I took out the water pump and started it with an external power supply. I found that the water pump could not run
Switching the water pump mode makes it impossible to operate
Alarm: pump speed too low
How to detect whether there is a problem with the pump body or the electric control board?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »lingyu« (18. Juni 2022, 14:40)
RBMDragon
Dienstag, 21. Juni 2022, 12:21
I hope you didn't run the pump dry.
(It needs water as lubrication, or else the impeller gets damaged)
