• 30.11.2026, 23:03
knacker
Leakshield filling question
Donnerstag, 30. Juni 2022, 10:19
I have had to replace some tubes and the fluid in my system and need to refill the loop. I not tried using the Fill action as I previously just filled it the old fashiioned way
Can I use a drain port, connect tubing to fill and also, if I have to have the pc on standby, how will the leakshield work?
I am sorry if I am being more stupid than normal but I am almost 50 and losing it quikly! :wacko: :D :D
PocketLeak
Donnerstag, 30. Juni 2022, 15:06
Connecting to the drain should work fine, mine is connected to an open port on my GPU and works great. I bought a USB to Motherboard USB cable and connected my leakshield to a battery pack I had, alternatively you can set your USB to stay on when in standby via your BIOS.
knacker
Montag, 4. Juli 2022, 13:41
thanks for the reply- I will try to enable USB on for my Asus motherboard- Google here we come!
Just ordered a new cable mini connector to USB so should make it easy to do ;( :D
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »knacker« (4. Juli 2022, 15:08)
