• 14.11.2026, 05:11
Ytterbium
High speed fan
Mittwoch, 13. Juli 2022, 22:22
Hello,
I have a Delta FFB03612EHN-BGA 36 mm fan connected to my Quadro, the maximum speed specification is 14500 rpm +/- 10%, the software only allows up to 10000 rpm so the graph is not correct.
Also the reported maximum speed is 17840 rpm so about 23% above the maximum specification so it seems that it can not be read correctly.
Can you consider to increase the graph axis to say 15000?
Do you have some sugestions on how to get correct speed measurements?
cptninc
Donnerstag, 14. Juli 2022, 03:38
As a short term solution, you could use the Playground to create an output that is that fan's RPM divided by 1000. You could then have the graph itself be based on that variable and have the displayed real time value be the direct fan speed.
