• 09.10.2026, 02:03
andsoitgoes
Upgraded to recent NVIDIA Drivers (516.59), having issues with AquaComputer Service, will start then be shut down
Samstag, 16. Juli 2022, 07:12
hi all,
This happened a little while back when I was doing some occasional mining on my computer. I would load up my software and it would run all would be fine then BAM I would get an error showing the AC service died, and I'd lose access to the web export data and so on.
I stopped mining a few months ago and disabled all that stuff, and realized I was stuck on a 3-4 version old driver, updated and I'm back to the same issue.
I've tried searching to see if this is a problem or if it's related to stuff like the cheating system in Elden Ring, but I just want to be able to use my system and use the service.
What's the AC service doing to cause this insanity? Why is it constantly being killed?
If I downgrade, it fixes this problem but then creates the problem of old drivers.
Thanks in advance.
Samstag, 16. Juli 2022, 12:44
I also have GeForce Game Ready Driver 516.59, with no AC Service issues. There maybe something else also involved.
Remayz
Samstag, 16. Juli 2022, 15:40
same deal. Updated recently from december drivers, no issues at all.
Samstag, 16. Juli 2022, 17:37
Same. Asus TUF RTX 3080 running NVidia Game Ready Driver v516.59 WHQL, Aquasuite updated to X.55. No problems.
andsoitgoes
Sonntag, 17. Juli 2022, 02:45
Okay, the plot thickens!
Do you all have the GeForce Experience installed on your computers? I'm going to start removing things one at a time to see what helps. I just know the second I updated the GeForce drivers, I kept getting the service error where it will start then stop.
Not sure how to best troubleshoot this.
Found this in my Event Viewer for the AC service:
Quellcode
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
Application: AquaComputerService.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
   at MimeKit.Utils.CharsetUtils..cctor()
Exception Info: System.TypeInitializationException
   at MimeKit.ParserOptions..ctor()
   at MimeKit.ParserOptions..cctor()
   at MimeKit.MimeMessage..ctor()
   at g4ippcQeZpn5Dro5w6E.jRpN9MQTvlTNEX1IKC6+<Mail>d__39.MoveNext()
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at g4ippcQeZpn5Dro5w6E.jRpN9MQTvlTNEX1IKC6+<OnNotificationEvent>d__27.MoveNext()
   at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
   at System.Threading.ThreadPoolWorkQueue.Dispatch()
Quellcode
1
2
3
4
5
6
7
8
9
10
11
Faulting application name: AquaComputerService.exe, version: 10.2.8221.26732, time stamp: 0x62c433b9
Faulting module name: KERNELBASE.dll, version: 10.0.22000.795, time stamp: 0x960371d1
Exception code: 0xe0434352
Fault offset: 0x000000000004474c
Faulting process id: 0x1dd0
Faulting application start time: 0x01d898d31b032e74
Faulting application path: C:\Program Files\aquasuite\AquaComputerService.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: b4fbf36f-7538-4724-bc2f-83c4c797c6a2
Faulting package full name:
Faulting package-relative application ID:
Quellcode
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
Fault bucket 2188215857619676168, type 5
Event Name: CLR20r3
Response: Not available
Cab Id: 0
Problem signature:
P1: AquaComputerService.exe
P2: 10.2.8221.26732
P3: 62c433b9
P4: MimeKit
P5: 3.3.0.0
P6: de1d040c
P7: 3c7
P8: 0
P9: System.TypeInitialization
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.715d9063-2c09-48ed-9df1-f753b580ce18.tmp.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.e35fec79-ccd1-422f-84e1-49a5e2dab0d2.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.d2e05c16-98eb-44dc-9b4c-a1d7dd9bb982.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.48e25122-f78c-435a-b2fa-5de160c7a726.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.59346870-71e3-4352-b2cd-8db4f576762f.tmp.txt
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_AquaComputerServ_0fb99cb5b11c4b33fead791bc9993debb36bda4_c6d46dd0_d28b48a6-3a24-41d4-becf-0ccb2a8f344a
Analysis symbol:
Rechecking for solution: 0
Report Status: 268435456
Hashed bucket: 50457a28e0c95d99ae5e1aba954c2c08
Cab Guid: 0
Tried to restart the service, runs and all is working for all of 1 minute until I get these in my event logs:
Quellcode
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
Quellcode
1
2
3
4
5
6
7
8
9
10
11
Faulting process id: 0x4a00
Faulting application start time: 0x01d899776fad1168
Report Id: 3ebf2542-6707-4950-a7cb-a02465d33f89
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »andsoitgoes« (17. Juli 2022, 02:53)
Remayz
Sonntag, 17. Juli 2022, 03:20
I tend never to install bloatware :P no Geforce experience nop.
Sonntag, 17. Juli 2022, 04:41
I did use GeForce Experience to update the drivers. I did select "clean install", which I know is not the same as using DDU to delete the old drivers first. So far, I have not had any problems updating video drivers through GeForce Experience.
Are you by chance using the AMBIENTpx effect to have video drive LEDs? Also, your 3rd screen shot lists a bunch of files. Maybe looking at these would tell you something.
andsoitgoes
Sonntag, 17. Juli 2022, 22:11
I do the same with the clean install each time, as well. I know something changed in some of the later Nvidia drivers for LHR cards that can mess with things.
Does everyone here have a LHR card?
Also, no I'm not using the Quadro to control any LEDs, only using MSI's Dragon Center since that's all I can with my motherboard.
As to the files, sadly those directories are always empty when I check them, it's really frustrating.
I tried it again. The service always crashes after a minute and puts files here:
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_AquaComputerServ_0fb99cb5b11c4b33fead791bc9993debb36bda4_c6d46dd0_48ff822b-7fc1-46ad-b104-0abe0d65a135
Except I can't even gain access to the folder, and I can't even find a way to get permission to the folder, even if I brute force apply a security change it doesn't do anything, I still can't gain access.
And the logs, again - but more recent:
Quellcode
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
Quellcode
1
2
3
4
5
6
7
8
9
10
11
Faulting process id: 0xf34
Faulting application start time: 0x01d89a19632a0169
Report Id: 738cca2a-77d1-43ac-a8c5-f3f29d925e83
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »andsoitgoes« (17. Juli 2022, 22:20)
Montag, 18. Juli 2022, 05:06
I have as Asus TUF 3080 OC - 10G VRAM, not LHR. It's one of the original Asus models.
Hopefully one of the Aquacomputer devs will read this thread. They may be able to figure out what is happening I have never used MSI Dragon Center but I have heard that this program can be problematic. If you are disabling things, maybe try disabling that.
andsoitgoes
Dienstag, 19. Juli 2022, 02:44
I've messaged support with a link to this thread.
I've downgraded my drivers, no dice. Still kills itself after a minute.
DragonCenter is vital, I can't control my LEDs without it, so sadly turning it off is a no go, it's very finicky and has been installed since day one of the PC, hasn't been an issue.
Fingers crossed, but this is insanely frustrating, nothing I seem to do solves the issue.
WinstonWoof
Dienstag, 19. Juli 2022, 07:31
So you've updated the GPU drivers but have you tried reinstalling Aquasuite?
personally that would be my next step,
Dienstag, 19. Juli 2022, 07:34
This looks like an issue with a missing character set or an other dependency.
Try a to replace this: MimeKit.dll from the zip file in your aquasuite install folder. Restart your computer/aquasuite service.
Fix this version the error?
»sebastian« hat folgende Datei angehängt:
  • MimeKit.zip (392,42 kB - 108 mal heruntergeladen - zuletzt: 28. September 2026, 02:15)
andsoitgoes
Dienstag, 19. Juli 2022, 21:41
Thank you for the reply sebastian, sadly that fix didn't work.
Replaced the file, restarted the computer and by the time I opened Aquasuite, I received the same errors:
Quellcode
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
   at MimeKit.Header.Unfold(System.String)
   at MimeKit.Header.SetValue(MimeKit.FormatOptions, System.Text.Encoding, System.String)
   at MimeKit.Header..ctor(System.Text.Encoding, MimeKit.HeaderId, System.String)
   at MimeKit.HeaderList.set_Item(MimeKit.HeaderId, System.String)
Quellcode
1
2
3
4
5
6
7
8
9
10
11
Faulting process id: 0x1b5c
Faulting application start time: 0x01d89ba6f87d634b
Report Id: 8fd0f29c-884f-4642-b0a2-ca16746f6e5a
in the email I replied to, I mentioned that this STARTED showing up in my event viewer logs the day after the most recent aquasuite update, x.54. I checked my installed programs and the date in the application and it matches up.
So it seems that something in this version is creating these issues. Maybe I can downgrade and see if that will help?
Dienstag, 19. Juli 2022, 21:51
try a clean aquasuite install with the setup. maybe this is an issue with your settings.
andsoitgoes
Dienstag, 19. Juli 2022, 22:06
is that going to require I rework and reset everything? I've spent a long, long time working on getting Aquasuite set up in a specific way, is there any way I can preserve at least some of the settings so I don't need to start from scratch?
Or at least save stuff so that if it doesn't work I can revert without losing everything?
Thanks for the speedy reply!
andsoitgoes
Dienstag, 19. Juli 2022, 23:34
Was able to brute install the x.55 version, got the service running long enough to check and install.
Restarted.
Logs below:
Quellcode
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
   at n9DoI449ngJJk23m29W.FlK6lV4n3FIIIm8Gehv+<Mail>d__39.MoveNext()
   at n9DoI449ngJJk23m29W.FlK6lV4n3FIIIm8Gehv+<OnNotificationEvent>d__27.MoveNext()
Quellcode
1
2
3
4
5
6
7
8
9
10
11
Faulting application name: AquaComputerService.exe, version: 10.2.8229.14146, time stamp: 0x62ce5d65
Faulting process id: 0x187c
Faulting application start time: 0x01d89bb622030441
Report Id: 3ac4531b-de65-4291-89de-87ebc0577723
So if there's a way to save the settings, I'd love to do that and try a full reset.
I was going to look into a system restore pre-7/6 but the earliest restore point is 10 days ago, sadly.
Thanks in advance.
andsoitgoes
Mittwoch, 20. Juli 2022, 04:02
To confirm - this seems to have solved the problem.
Only issue is the previous settings are still locked away, I copied the profile folder and it.... didn't change anything. None of my virtual sensors or ugh, email accounts were saved and sadly I thought it would be in the programdata info, it wasn't.
andsoitgoes
Mittwoch, 20. Juli 2022, 04:14
THE
PLOT
THICKENS
So, seeing as I had to start from scratch even after copying the profile info in, I added my email account.
Set it up, confirmed the password, saved it, hit test - bam, service crashes.
SO something is happening with the email server. Makes sense, last email notification of temp updates was on the 6th of July.
Mittwoch, 20. Juli 2022, 07:25
I can confirm this, my X.55 also loses contact with the Aquasuite service when I trigger a mail.
Under background service, the service is still displayed as "The service is running".
After the first reboot as administrator I tried this again, the service continues to run , according to the display, and I can stop and restart it.
Any attempt to send a mail stops the connection to the service .
Mail provider is Strato
Translated with www.DeepL.com/Translator (free version)
WinstonWoof
Mittwoch, 20. Juli 2022, 08:18
To clarify is that:
a) X55 Loses connection with the AS service when X55 is sending a mail
or
b) X55 loses connection with the AS Service when a mail is sent from a mail client on the same PC ?
As these are two different scenarios
NB you dont need to restart X55 in admin node to check on if the AS service is running|stope|start it, just open up the services window on the PC and check there. I've also set mine so that instead of take no action on failure it autorestarts
