• 01.11.2026, 18:52
Top_Nurse
Inline filter mount question
Donnerstag, 28. Juli 2022, 06:43
I posted the pic as the one I have isn't exactly the same as what is currently sold, but I would imagine the mount is the same (mine is a G 1/8 ). In the store, I noticed that they sell some mounts other than what comes with the filter. I removed one of the vertical Aquatubes in my Feeding Frenzy project and would like to get a mount that has roughly the same external dimensions as a standard Aquatube mount. Does anyone happen to know whether the 92mm size would work?
Jacob
RE: Inline filter mount question
Sonntag, 31. Juli 2022, 11:50
Zitat von »' work?[/quote«
The most suitable way is to choose the mounting bracket according to the size of the fan.
Or use hard tubes as a bracket for support. :)
https://shop.aquacomputer.de/product_inf…roducts_id=2529
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Jacob« (31. Juli 2022, 11:53)
Top_Nurse
RE: RE: Inline filter mount question
Sonntag, 31. Juli 2022, 22:37
Thanks Jacob for the idea of using a hard tube. I'll have to mull that over. :)
I'm kind of surprised that AC didn't make any aluminum mounting plates. ?(
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Top_Nurse« (31. Juli 2022, 22:52)
