• 12.10.2026, 23:21
pangeng
i am new to aquaero and i use windows xp, may i ask how to download the older version of aquasuite.
Sonntag, 7. August 2022, 16:30
I am installing aquaero and related watercooling system to my old pc which uses windows xp.
may i ask how can i download the older version of aquasuite for windows xp. as far as i searched, current aquasuite need as least windows 8 as it requires NET.framwork4.6.1
thank you.
Sonntag, 7. August 2022, 17:47
You can only download the software here https://aquacomputer.de/software.html
You will then be offered the Aquasuit version that matches your devices, i.e. the firmware version.
If the devices are new and have a current firmware, there is no possibility to use an old Aquasuite version.
Wasmachineman_NL
Sonntag, 7. August 2022, 23:29
Lemme hijack this thread for a related question: does the Aquaero 5 support XP?
Sonntag, 7. August 2022, 23:56
I believe the aquaero 5 runs under any operating system, all it needs is 12/5 volt input.
According to Taubenhaucher, if the firmware is the same as when you ran XP, you should be able to download the pertinent aquasuite version.
WinstonWoof
RE: i am new to aquaero and i use windows xp, may i ask how to download the older version of aquasuite.
Montag, 8. August 2022, 09:58
thank you.
The problem is that XP (people are still using that as a daily ??) only supports the Dot Net framework below version 4.5 so any program using an up to date patched version of Dot NET framework will not run
That's a legacy unsupported OS limitation
https://devblogs.microsoft.com/dotnet/p/dotnet4xp/
Montag, 8. August 2022, 12:04
Windows XP is not supportet.
pangeng
Dienstag, 9. August 2022, 14:23
thank you. :)
