• 09.11.2026, 13:32
dfmastin
Not enough USB 2.0 headers
Montag, 29. August 2022, 02:28
I purchased a NZXT Internal USB Hub 3 that works quite nicely except it does not pass power though to the headers when the computer is off/standby such that my Leakshield can’t do it’s job.
Does anyone know of a usb 2.0 splitter that will pass through power when the computer is off/standby.
Note: without the splitter my motherboard’s usb 2.0 passes power through when off/standby just fine. Problem is I only have one head which I can use for two devices, but I have a Leakshield, NEXT high flow, and Octo.
Montag, 29. August 2022, 05:50
Hubby7
If power is supplied via USB, depending on motherboard configuration, power will also be supplied during standby of the PC
Edit: do NOT use the SATA power connector
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (29. August 2022, 05:53)
dfmastin
Montag, 5. September 2022, 19:05
Thanks so much InfoSeeker.
My new Hubby7 is working perfectly as intended.
