• 18.11.2026, 16:45
dfmastin
Where to change third party pump and reservoir parameters?
Freitag, 2. September 2022, 18:10
In Aquasuite, how do I change the base settings for a third-party pump/reservoir?
When I first set up Aquasuite it asked me some basic questions about the pump and reservoir.
Now, after seeing that my fill level estimation is a bit off, I’d like to change some of my pump/reservoir parameters.
I cannot find where to do this. Any advice? Thank you. I’m impressed with Aquasuite.
dfmastin
Montag, 5. September 2022, 18:45
I found it!
In Aquasuite go to LEAKSHIEL settings then select sensors then select pump speed.
From there you can tweak your user define pump parameters if you did not make correct choices when first setting up.
