• 14.11.2026, 07:22
red-ray
Is x an SI Unit?
Freitag, 7. Oktober 2022, 01:08
I am starting to look into the X.59 playground virtual sensors and there is a "x" sensor unit, see attachment one.
I have checked the Si unit specifications and not found a x unit, what is it?
Looking further no fractional decimal digits are reported, when there should be a lest one. I's rendered as 94 x when it should be 94.1, why is this? See attachment two.
»red-ray« hat folgende Bilder angehängt:
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »red-ray« (7. Oktober 2022, 01:20)
Freitag, 7. Oktober 2022, 10:39
The 'X' unit is simply a place holder if none of the listed units apply, it works similarly to not assigning a unit.
It does appear both applying the 'X' unit, or no unit, causes the aquasuite to round to the nearest unit digit for the final value,
Freitag, 7. Oktober 2022, 11:06
no.
you can use the "x" as factor (CPU clock multiplier ...) for a non unit use "- - -".
red-ray
Freitag, 7. Oktober 2022, 12:42
OK, but why is the decimal digit absent?
Further for a CPU multiplier it should be such as x4.5 not 4.5x
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »red-ray« (7. Oktober 2022, 12:55)
