• 14.11.2026, 04:12
Ytterbium
Pressure cycling
Sonntag, 23. Oktober 2022, 10:32
When my leak shield starts up in to monitor mode it really overshoots the pressure and end up in a strange cycling patter until it finally settles to the correct pressure.
Any suggestions
red-ray
Post a screen shot of the whole X.59 Status screen
Sonntag, 23. Oktober 2022, 11:18
Mine has never done this and from just the graph I can't even guess what may be causing this. Post a screen shot of the whole X.59 Status screen and also export the event log and attach it
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »red-ray« (23. Oktober 2022, 11:20)
Ytterbium
Sonntag, 23. Oktober 2022, 12:41
There's nothing exciting in the logs just the cycling effect.
red-ray
Sonntag, 23. Oktober 2022, 13:09
I am surprised there are no P1 + P2 + Q + D Waterproof Membrane values, but as you failed to post the event log I asked for I can't see what happened before the cycling.
Currently my best guess is that either that the Level Measurement failed or never happened and there is now a lot less than 107ml of air in the reservoir
Were it my system I would do as follows:
1) Save the current event log and then clear it.
2) Set the mode to Release
4) Wait 15 seconds
5) Set the mode to Monitor and see what happens, it should so a Measure Level and then the P1 + P2 + Q + D Waterproof Membrane values should be reported.
6) As to what I would do next would depend on what happened
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »red-ray« (23. Oktober 2022, 13:15)
Ytterbium
Sonntag, 23. Oktober 2022, 22:04
Same as before, there was a warning that the membrane was not function to expectations.
LEAKSHILED 10438-20652
Date: 23 Oct 2022, 22:00
ID: 171 T: 10 23 2022 22:00 Event: ShieldPressureHigh Mode: Monitor State: Protected P: 276.4 P_rate: NaN V_rate: NaN V1: 1000 V2: NaN
ID: 170 T: 10 23 2022 22:00 Event: ShieldPumpFinish Mode: Monitor State: Pump P: 248.2 P_rate: NaN V_rate: NaN V1: NaN V2: NaN
ID: 169 T: 10 23 2022 22:00 Event: ShieldPressureLow Mode: Monitor State: Unprotected P: 52.9 P_rate: NaN V_rate: NaN V1: 500 V2: NaN
ID: 168 T: 10 23 2022 22:00 Event: ShieldPressureHigh Mode: Monitor State: Protected P: 274.2 P_rate: NaN V_rate: NaN V1: 1000 V2: NaN
ID: 167 T: 10 23 2022 22:00 Event: ShieldPumpFinish Mode: Monitor State: Pump P: 225.5 P_rate: NaN V_rate: NaN V1: NaN V2: NaN
ID: 166 T: 10 23 2022 22:00 Event: ShieldPressureLow Mode: Monitor State: Unprotected P: 52.9 P_rate: NaN V_rate: NaN V1: 500 V2: NaN
ID: 165 T: 10 23 2022 22:00 Event: ShieldPressureHigh Mode: Monitor State: Unprotected P: 252.4 P_rate: NaN V_rate: NaN V1: 1000 V2: NaN
ID: 164 T: 10 23 2022 22:00 Event: ShieldPumpFinish Mode: Monitor State: Pump P: 187 P_rate: NaN V_rate: NaN V1: NaN V2: NaN
ID: 163 T: 10 23 2022 22:00 Event: ShieldPressureLow Mode: Monitor State: Unprotected P: 52.8 P_rate: NaN V_rate: NaN V1: 500 V2: NaN
ID: 162 T: 10 23 2022 22:00 Event: ShieldPressureHigh Mode: Monitor State: Protected P: 276.9 P_rate: NaN V_rate: NaN V1: 1000 V2: NaN
ID: 161 T: 10 23 2022 22:00 Event: ShieldPumpFinish Mode: Monitor State: Pump P: 294.2 P_rate: NaN V_rate: NaN V1: NaN V2: NaN
ID: 160 T: 10 23 2022 22:00 Event: ShieldPressureLow Mode: Monitor State: Unprotected P: 52.5 P_rate: NaN V_rate: NaN V1: 500 V2: NaN
red-ray
Sonntag, 23. Oktober 2022, 22:15
Ah, I suspect this is the root cause of the overshoots, but I have no idea what caused this to how to fix it.
It would be sensible to post a screen shot of exactly what was reported, were there any error codes?
I suspect you should email support@aqua-computer.de, include as much detail as possible
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »red-ray« (23. Oktober 2022, 23:27)
Montag, 24. Oktober 2022, 06:39
Probleme mit Leakshield und Fillport
Translation from the above post:
Your membrane is clogged. You can see this from the spikes in the pressure curve. Change your coolant and drip a few drops of isopropnaol onto the membrane. Wait 5 minutes, vacuum with kitchen roll without touching and repeat this 5 times. If the peaks remain, then the membrane must be replaced.
