• 30.11.2026, 22:39
Taimer
AquaSuite stopped reading HWiNFO
Montag, 7. November 2022, 20:58
AquaSuite stopped reading HWiNFO sensor values after installing the latest version of HWiNFO . Please tell me what can be fixed.
»Taimer« hat folgende Datei angehängt:
Hufeisen
Montag, 7. November 2022, 21:38
You have to manually enable Shared Memory Support in the HWInfo Settings. This was changed in HWinfo Version 7.
If you use the free version of HWinfo, shared memory support is limited to 12 Hours.
If you want permanent shared memory information, you have to buy HWinfo Pro or use HWinfo Version 6.42 or lower.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Hufeisen« (7. November 2022, 21:45)
Taimer
Montag, 7. November 2022, 22:09
Thanks
Kyle XY
Mittwoch, 28. August 2024, 22:28
Since several new versions of HWiNFO, it appears that AquaComputer is no longer able to read HWiNFO values. There is only :
> Data from Aqua Computer Service
> Aqua Computer Hardware Monitor
> Time
> aquasuite
> aquaero (.......)
Is there a reason ? Do you meet the same problem ? At present, I have Aquasuite X.79
Donnerstag, 29. August 2024, 03:25
I am running Aquasuite X.79 and HWINFO v8.11-5526 beta (released today), and Shared Memory data is showing up in Aquasuite. I have not had any problems with the last few versions of HWINFO.
There was a -5525 beta released earlier today with a bug that affected WHEA and Custom sensors. I did not install -5525 beta so I don't know if Shared Memory Support was also affected. Version 5526 beta was released about 13 hours later with the bug fixed. If you are running HWINFO v8.11-5525 beta that might be the problem.
v8.11-5525 beta announcement - WITH BUG
v8.11-5526 beta announcement - BUG FIXED
