• 11.11.2026, 19:23
demilleroh
Aquaero 6 LT - Data Log Synchronization not working
Donnerstag, 5. Januar 2023, 03:35
I want to use the Aquaero data synchronization function to “fill gaps” in Aquasuite Data Log files
( like when Aquasuite is not running ).
Here’s the basic sequence I used for a controlled test, as I've never been able to get synchronization to work.
1. At 7:04 PM, in Aquasuite, I deleted the Calitemp 2 log data, let it log about 2 minutes, then set it “inactive”
2. At 7:06 PM, I deleted the log files on the Aquaero 6 LT. and let Aquasuite running.
3. At 7:22 PM, in Aquasuite, I set the Calitemp 2 log data file "active" ( this created a "gap" ).
4. At 7:24 PM, in the Aquaero 6 LT, I executed the synchronize log data function and exported the XML data.
5. At 7:26 PM, in Aquasuite, I checked the data ( the gap was not “filled” ) and exported the XML data.
This process was done without Aquasuite being started in an elevated state. I have
tried it elevated. It doesn’t work then, either.
Should this process “fill the gap” ? Can it if done correctly ?
A picture of the Aquaero XML data is in the attachments.
A picture of the Aquasuite XML data, after the Aquaero synchronize, with the gap, is in the attachments.
Here is addidtional supporting detail:
Attachment 1 – Aquaero – Calitemp 2 – AE sensor configuration
Attachment 2 – Aquaero – Calitemp2 – AE data log configuration
Attachment 3 – Aquasuite – Calitemp2 – AE data log configuration
Attachment 4 – Aquasuite – Unfilled gap after Aquaero synchronize
Attachment: XML Data - Exported from Aquaero 6 LT
Attachment: XML Data - Exported from Aquasuite - Calitemp 2 Data Log
Thank you.
»demilleroh« hat folgende Dateien angehängt:
Donnerstag, 5. Januar 2023, 07:25
Currently this function does not work properly.
demilleroh
Future Plans
Donnerstag, 5. Januar 2023, 14:02
Sebastian - Thanks for the reply.
Are there any plans to address the issue in the future ? Like maybe in an Aquasuite release update ?
