Du bist nicht angemeldet.
RuffHi
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »RuffHi« (13. Januar 2023, 12:23)
RuffHi
RuffHi
Well ... yes but not as crudely as thatI don't speak xaml... but I can order a beer and ask where is the bathroom
Is this along the lines of what you want to do? ([attach]9987[/attach])
. At least you illustrated that I can put something as a background but I am guessing(!) not an interactive background. I would classify this as a baby step forward. Thanks for the start
RuffHi
Looks like you found the spinning fan. Good luck, and please post your progress. I am very interested in your findings.
AIDA64 also allows custom "sensor panels" to be set up. There is a THREAD on their forum dedicated to custom sensor panel layouts. Some people have built very complex and impressive displays - custom fonts, moving backgrounds, etc. You can do way more with an AIDA64 sensor panel than you can with an Aquasuite Overview Page. I have played around with it but I don't want to have to run AIDA64 because I am already running Aquasuite and HIWINFO, which is importing data into Aquasuite. Adding another program that is polling sensors is not a great idea because it increases load on the system and the chance of polling collisions. Since I use Aquasuite to monitor and control all of my cooling hardware, I decided to use their Overview pages even though it is much more limited than AIDA64's sensor panel feature. If you can't accomplish what you want in Aquasuite, you could consider using AIDA64 for your sensor panel instead of building an overview page in Aquasuite. Then use AIDA64 to poll sensors instead of HWINFO, and disable all direct sensor polling in Aquasuite. If I ever decide to use AIDA64 sensor panels instead of Aquasuite Overview Pages, that is how I would set things up.
Grestorn
