• 13.10.2026, 05:40
Methodical
Aquasuite RGB...what's the difference between their RGB Led and RGBpx lights?
Dienstag, 17. Januar 2023, 17:59
Hello. I am new to working with led lights and considering adding a couple led strips to my PC. However, I see Aquasuite offers two flavors of Leds.
1. What are the differences between the RGB leds and the RGBpx leds light strips other than the point of connection?
2. When installing leds is it best to use a strip that is almost the full length of the case or a few inches shorter than the length of the case for best lighting?
Thanks...Al
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
Remayz
Dienstag, 17. Januar 2023, 20:05
check the product description.
I believe those just called "RGB strip" are 12V analog RGB to be used with the farbwerk controller or 4 pin RGB on motherboards.
RGBpx is the 5V adressable RGB for use with Farbwerk360 or other controllers with RGBpx ports. it's also compatible with regular ARGB with an adapter to the 3 pin connectors
Methodical
Freitag, 20. Januar 2023, 05:44
Thanks
