• 30.11.2026, 22:21
pagratios
Quadro not connected after PC wake
Dienstag, 24. Januar 2023, 19:02
Hello team,
I am new to custom loop and to aquacomputer products. I have a Quadro and via aquasuite I monitor temps and Fans.
When I put my Windows11 desktop to Sleep mode and then wake it up the the aquasuite show quadro as disconnected.
I have tried to restart windows Service and Aquasuite but no success. Only restart of the Desktop fixes the issue
Is there any way to make it work because I am using a lot the Sleep mode
pagratios
Montag, 30. Januar 2023, 11:26
Does anyone from aquacomputer can help with this?
I put my PC to Sleep most times in the week, but know I am not able to do it due to above issue.
Grestorn
Montag, 30. Januar 2023, 11:56
You should contact support@aquacomputer.de directly.
This forum is not constantly watched by AC support employees.
Montag, 30. Januar 2023, 22:53
I have seen several posts about AQS and the AQS service not resuming properly after a computer running Windows 11 goes to sleep or hibernates. I personally have not experienced this problem because I am not running Windows 11 and I don't let my computer go to sleep or hibernate. Just wanted to say that you are not the first person who has reported this. I don't recall if the other posts were in the English forum or the German forum but I think they were posted after AQS was updated to version X.66.
Dienstag, 31. Januar 2023, 07:34
Maybe an update to the lastest Insider Version can help.
This is usually not an aquasuite problem.
This may be a driver problem or the order in which Windows loads the drivers.
pagratios
Samstag, 4. Februar 2023, 11:44
I installed the insider x.66 version, although the issue is still here :(
Grestorn
Samstag, 4. Februar 2023, 15:31
You can tell Windows to restart the service automatically in case it's failing for whatever reason.
pagratios
Sonntag, 5. Februar 2023, 18:01
The issue isn't with service, which is running after wake up. something with the usb might be the issue
