• 30.09.2026, 11:45
CmdrFlemming
I cannot launch aquasuite-setup.exe on fresh Windows 11 installation (Solved)
Donnerstag, 16. Februar 2023, 08:36
[*]When I launch the installer I get prompted by Windows 11 UAC.[*]I then reply YES to let it run.[*]Then absolutely nothing else happens?
aquasuite X.66 (Insider) (19.01.2023)
Quellcode
1
2
3
4
5
C:\Users\XXX>dotnet --list-runtimes
Microsoft.NETCore.App 7.0.0 [C:\Program Files\dotnet\shared\Microsoft.NETCore.App]
Microsoft.NETCore.App 7.0.1 [C:\Program Files\dotnet\shared\Microsoft.NETCore.App]
Microsoft.WindowsDesktop.App 7.0.0 [C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App]
Microsoft.WindowsDesktop.App 7.0.1 [C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App]
My Quadro is detected and present as a USB device and the setting from my previous Windows 10 is working and controlling the watercooling system... i just need the Aquasuite now to make a few changes!
Any advice is appreciated very much.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »CmdrFlemming« (16. Februar 2023, 15:32)
Donnerstag, 16. Februar 2023, 11:34
Disable your Anti Virus/Firewall when you not use the Windows Default Defender/Firmware.
Do you have any feeback when you click install?
Take screenshots and upload them here in the forum.
Preferably from the time when everything is still running, just before it stops working.
Do you have any error logs in Windows?
CmdrFlemming
Donnerstag, 16. Februar 2023, 15:16
Thank you for reply.
You gave me new leads to follow, and it helped.
I already tried to disable firewall in windows 11, and all other stuff i have that *might* interfere with the installation including my PiHole DNS server... but it didnt change anything.
I did look for errors in eventviewer before i posted here for help but could not find any logs... like there was NOTHING that mentioned aquasuite-setup.exe or anything in that alley. I didn't think about the total absense of logs until your question about error logs in windows... that made me ReDownload the installer fresh from your website - and Viola! now it works.
The first download must have been damaged in transit or something ?(
Thank you for the help to find the solution :thumbup: and thank you for an awesome product!
o7 CmdrFlemming
