• 07.10.2026, 01:00
Hort
Fan stop behaviour on Quadro with new firmware
Dienstag, 21. Februar 2023, 15:29
Hello! Recently I've updated my Quadro to the latest stable software and firmware versions (aquasuite X.59 and 1032 firmware). Previously if I unselect "Hold minimum power" and temperature goes below Minimum temperature - fan stops. When temperature goes above Startup temperature - it starts. After update the fan started to behave weirdly - it can stop without reaching Minimum temperature. Sometimes it keeps starting and stopping all the time if difference between Minimum and Startup temperature is 1-2C (without even reaching Minimum temp and changing temperature at all). Tried to reset device to factory defaults, but this didn't help. I have also aquaero 6 LT with older firmware/aquasuite on a different computer and it stops fans only when temperature is lower than Minimum, not somewhere in the middle
Dienstag, 21. Februar 2023, 15:57
Make screenshots from your fan and controller settings.
Hort
Dienstag, 21. Februar 2023, 16:21
The fan starts when temperature is 37 (as expected) but stops at around 36.29, although minimum temp is 35
»Hort« hat folgendes Bild angehängt:
Dienstag, 21. Februar 2023, 16:27
Yout first 3 point are very close to 0%.
Set only the first point too 0, all other > 0
Hort
Dienstag, 21. Februar 2023, 17:06
I have "minimum power in" set as 30% and fan spins at 30% before stopping, so it should be 30 in that case, not 0?
Hort
Dienstag, 21. Februar 2023, 17:18
I've tried your suggestion - and it works now. Last 3 point were indeed 0%. Thanks a lot!
Hort
Dienstag, 21. Februar 2023, 17:50
It should be some kind of bug with rounding - first 3 points were 0%, but 4th - 2.1% already. I would expect 1.x% at least in between, not all 0-s. To get this I used Automatic setup.
Hort
Dienstag, 21. Februar 2023, 17:57
It looks like it's a bug with Manual setup - when I used Automatic setup, I see that at least some of them are not 0-s, but when I try to select them one by one in Manual setup - they are all changed to 0% automatically, except 4th 2.1%
