• 06.11.2026, 18:13
Wim
Using quadro and HFN without direct connection
Mittwoch, 5. April 2023, 13:18
Hello
I sadly didn't know I had to order an extra cable to connect the flow sensor on the HFN to a quadro. So I'm wondering if both are connected with the included USB cable to the motherboard, will the software be able to read the temperature and flow from the HFN and then use those values to tell the quadro what to do?
If not, do I only need to order cable 53212, or do I also need another cable to transfer the TEMP values to the quadro? What other cable would I need for that? Or should I use an aquabus cable instead? :huh:
Thank you in advance.
MaxTwister
Mittwoch, 5. April 2023, 13:36
The Software Aquasuite managed the connection of both hfn and quadro and you can the sensors combine it works over Usb
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »MaxTwister« (5. April 2023, 13:39)
:D
On CachyOS
Wim
Mittwoch, 5. April 2023, 14:38
Thank you for the reply!
