• 07.11.2026, 10:34
haaammit
"Input" location wrong on overview page
Samstag, 22. April 2023, 23:17
Hi - I'm slowly learning about aquasuite and I've been trying to add a slider control on an overview page, but whenever I put the input in the same place as say a gauge, it always appears quite a bit further down. For example, if I have horizontally a gauge, an input and then another gauge, the gauges display in the right place but the input is way way lower. Any ideas or am I missing something blindingly obvious?
I have a 7" screen that I use to display an overview page and I'd like to be able to maybe change profiles but using the touch screen so I can change profiles or maybe alter other things whilst in-game without having to alt-tab out!
Thanks
Sonntag, 23. April 2023, 04:55
Maybe this clip helps... if not, screenshots are helpful - input_on_deskto
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (23. April 2023, 05:00)
haaammit
Sonntag, 23. April 2023, 12:12
Hi and ty for the reply. I;ve put in some screen shots to show the issue. Let's say I have 3 items to display, In this instance it's a CPU usage gauge, a slider control and a cpu clock speed gauge. On this first screenshot I'm in aquasuite and have lined up all three on the same horizontal setting:
Now, exit the setup page and only the two gauges are showing:
Back in the setup page and the slider is set way higher - almost at the top of that screen:
And after exiting setup the slider is almost in between the gauges, but of course on the setup page is miles out!:
Sonntag, 23. April 2023, 13:13
Screenshots of the Settings tabs of the 3 objects may be useful
haaammit
Sonntag, 23. April 2023, 15:26
Here are screenies of the two setting pages, one of the gauge one of the slider. This is with the slider in the correct position within aquasuite, but it the isn't in the correct position when loaded up as a page
Gauge:
Slider
Let me know if you need any more info - thank you!
Sonntag, 23. April 2023, 16:23
Check the 'Y' position value of the slider object when you set it up initially (2065?), and again after exiting and reentering the setup page when the slider has shifted up
A screenshot of your Windows System > Display page would be useful also [display_setting.jpg]
haaammit
Sonntag, 23. April 2023, 16:40
Hi there. Here's the settings of the slider positioned incorrectly from within the page setup menu (but displaying in roughly the right position in the page) followed by a screenie of my display settings (I think)
ty ty
Sonntag, 23. April 2023, 17:27
It appears the 'Y' position is modified between initial specification and after being displayed on desktop (2065 -> 1210?) hard to read the numbers on the screenshots.
I do not have a clue what is happening there, but if it is close to correct on the desktop display, perhaps to offset the specification slightly to have it display where desired.
you may want to contact support@aqua-computer.de
Montag, 24. April 2023, 07:14
Currently we can not fix this. This happens when you use different Screen scalings in your monitor setup.
You can prevent this:
1. Arrange the elements so that they are correctly aligned on the desktop, then the preview in the aquasuite is just not right.
2. use only displays with the same scaling and resolution.
