• 11.10.2026, 02:54
klara
What happens if a PWM device connected to D5 NEXT try to draw more than 25W?
Dienstag, 25. April 2023, 15:45
D5 NEXT specification tells that it can provide 25W power through its PWM port.
What happens if I connect a device potentially can draw more than 25W?
For instance, I may connect a group of PWM fans with total maximum power of 30W.
Or, I may connect a PWM pump whose maximum power is 30W.
Is it just slow down the device with low RPM? Or maybe something bad could happen?
Dienstag, 25. April 2023, 15:50
The fan output is broken against.
This can happen even with less power if the fans have a high startup current.
This value is to be understood as an absolute maximum and must never be exceeded.
klara
Mittwoch, 26. April 2023, 07:30
Understood, thank you for your clear answer!
