• 13.11.2026, 12:38
Tanquen
Aquacomputer cuplex kryos Next - Work with AM5? - Offset bracket?
Mittwoch, 3. Mai 2023, 18:40
I don't think the Aquacomputer cuplex kryos Next AM4 / 3000 uses a backplate so it should be good for AM5 boards too?
Also, does the "Aquacomputer conversion kit socket AM4 / 3000 for cuplex kryos NEXT" offset bracket still make sense for the AMD 7000 CPUs? I would not think it would matter as long as the water block is in full contact with the CPUs heat spreader.
https://www.aquatuning.us/water-cooling/…c-glass-version
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Tanquen« (3. Mai 2023, 18:41)
Tanquen
Donnerstag, 25. Mai 2023, 02:23
It worked on the new AM5 Board and I used the offset bracket to center the block on the CPU.
