• 07.10.2026, 23:36
Kermit
more than 4 fans on the aquaero?
Mittwoch, 2. Februar 2005, 07:48
is it possible to control more than 4 fans?
stephane
friku
Re: more than 4 fans on the aquaero?
Mittwoch, 2. Februar 2005, 11:10
Yes, it´s possible.
I´ve made an Y cable splitter and have connected 3 12cm. papst fans on one channel, but I think it would be better stay with 2 fans on each channel.
Have in mind that you have 5W per channel. Look at the specifications of the fans you have to not overpass this limit.
Cheers,
friku.
Kermit
Mittwoch, 2. Februar 2005, 11:43
I have 4 fans:
PAPST 4412 F/2GLLL
they are 0.72W each
I have the big huge monster radiator, which I would like to cover with fans. :o ;D :o
fabelmann
Mittwoch, 2. Februar 2005, 12:12
this is possible. together, these 4 fans have less than 5 W (exactly 2,88). You could use all of your fans in one channel or each fan in one channel and then add other fans with an y-cable.
