• 03.09.2026, 06:55
CaptainOblivious
Aquasuite - No Connection to Aqua Computer Service - Every boot!
Samstag, 21. Oktober 2023, 02:39
I've verified I have full Permissions to the program.
I have enabled start on boot in the Aquasuite Settings.
I have even added the .exe to C:\Users\Me\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup.
But every time I boot up my PC I have to manually open Aquasuite program and click Start Service in the AQ Settings to resolve the error. Only then do my Profile settings take affect.
Screenshot of the error message:https://imgur.com/a/jLwDhVV
Sceenshot of my AQ Settings:
https://imgur.com/a/Q07e2zA
Please help!
Remayz
Samstag, 21. Oktober 2023, 17:06
maybe have a look at your windows services (open the start menu and type "services", the services app should pop up in the list).
Look at the aqua computer service and make sure its startup option is set to automatic
CaptainOblivious
Dienstag, 24. Oktober 2023, 19:32
I've done this and Aquasuite opens every time I boot but the Service is never started. The program is open but it says No connection to Service and I have to manually Start the service every boot.
Dienstag, 24. Oktober 2023, 19:53
try to install the new aquasuite update.
Make a clean install with the setup from the download section
apala4
Montag, 30. Oktober 2023, 10:59
Having this issue often. ususlly end up in non working aquasuite as it cannot start service.
last time I got it broken performed the following to fix
1) remove autostart (start at boot) for as much applications as possible (in my case it was a fresh Win installation so only dropbox, gdrive, avira, *torrent, steam)
2) reinstall aquasuite, configure all readings/sensors/etc
3) make sure it works properly with no issues after a few PC reboots
4) enable autostart for 1 application
repeat 3-4 unless you find that some program is blocking aqu asuite services from start
In my case it was *torrent app
