• 18.11.2026, 18:13
WaterBoy61
Can I add another Octo to connect a MoRa3?
Montag, 30. Oktober 2023, 23:28
I would like to know if a second Octo controller will work with my existing one. I do not have any more connections left on the existing Octo to connect two more water pumps and four Noctua fans. So I would like to know if another Octo will work with the Aquasuite software? The four fans are connected with a splitter , so there will only be one connection to the controller for the fans. There are two PWM connections from the pumps to connect too.
Dienstag, 31. Oktober 2023, 03:39
Yes you can have multiple Octo's no problem. Each one needs a USB connection to the mobo.
Methodical
Sonntag, 5. November 2023, 03:06
Or a Hubby, if no additional USBs.
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
