• 11.11.2026, 01:36
wibeweb
D5 next pump moisture detected ?
Dienstag, 31. Oktober 2023, 23:14
I have just installed my D5 next pump as well as the Leakshield
Everything goes well and everything is recognized correctly.
However, very regularly the “D5 Next” pump goes into alarm “Moisture detected”
I disassembled the pump and wiped: evreything seems to be fine.
The alarm comes back very quickly.
I noticed that if I am in "RELEASE" mode on Leakshield it does it less often?
Where do you think the problem is and how can I fix it?
Am I drying the pump incorrectly? Which part should I check first?
Thank you for your help
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »wibeweb« (1. November 2023, 04:56)
Mittwoch, 1. November 2023, 07:19
This happens when moisture gets into the pump electronics.
wibeweb
Mittwoch, 1. November 2023, 08:12
I completely disassembled the pump. I left it to dry for 6 hours and then, to ensure the effect, a little hairdryer to dry everything.
I finally put the pump back together and it seems to be OK now!
It was long, but the system is functional, the "leakshield" coupled with my "D5 next" pump (which makes no noise), ensures protection against leaks.
I took the opportunity to limit the 90° fittings on my loop and in particular those of the pump.
All I have to do now is clean and put the cables back in place, but I'm going to leave it like this for 48 hours to check that everything is okay!
