• 30.09.2026, 02:32
Ambient Sensor Placement
Mittwoch, 13. Dezember 2023, 18:40
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (13. Dezember 2023, 22:07)
Remayz
Mittwoch, 13. Dezember 2023, 19:37
I had the same problem when trying to relocate my hanging sensor in the case, on a push intake fan. the ambient was varying too much and the fan speed as a consequence was always too low, letting the coolant heat up more than it should (temp climbs fast, delta climbs slow because "ambient" rises too).
I quickly pulled it out again to hang outside the case and now it's more silent and cool again.
Montag, 18. Dezember 2023, 05:08
Thanks for posting this video that shows how important it is to keep ambient temperature sensors away from radiators. I am surprised the radiator had that much influence on the ambient temp senor, especially since the fans are not pushing hot air in that direction.
I am curious about the flow meter and the fittings that screw into it. IIRC from another post, that is a Blue-White F-400 series. I am considering buying one of these and have been reviewing their documentation. I think the model I want is the F-40_376_LN-4. F-400 Model Niumber Matrix.jpg
F = Flow Meter
40 = F-400 Acrylic Body
376 = 0.2 - 2.0 GPM (or ~1.0 - ~7.5 LPM)
LN = 316 Stainless Steel Rod
4 = 0.250" Female NPT, Polypropylene
Blank = Viton O-Rings
I am curious about which fitting option you have and what adapter fittings you are using to get to BSPP 0.25”. The spec sheet lists 3 options – 0.250”, 0.375”, and 0.500” Female NPT. Standard water cooling fittings are BSPP 0.25” with non-tapered threads. I found THIS brass adapter that is NPT 0.25” Male to BSPP 0.25” Female. If I got the flow meter with 0.250” NPT female threads, this fitting NPT 0.25” Male end would screw into the top and bottom of the flow meter and a standard BSPP 0.25” male fitting would screw into the BSPP 0.25” Female end. I also found THIS nickel-plated brass fitting that is also NTP 0.25” Male to BSPP 0.25” Female but it says it’s for hydraulic hose and I am not sure if the threads per inch are correct. It says the BSPP Male threads are 18 per inch but I think standard water cooling fittings have 19 threads per inch. Can you share what fittings you used with the flow meter?
Dienstag, 19. Dezember 2023, 16:53
I am curious about the flow meter and the fittings that screw into it. IIRC from another post, that is a Blue-White F-400 series. I am considering buying one of these and have been reviewing their documentation. I think the model I want is the F-40_376_LN-4. [attach]10577[/attach]
F = Flow Meter
That is correct, except I don't think every combination is an available option
The unit you specified does not appear to be available with the 1/4" F/NPT end connectors, either 3/8" or 1/2" are listed
I went with model F-40376LN-6 (3/8" F/NPT) (f400.jpg)
I have a 3/8" BSPP bottom tap that I have used in the past, but I did not tap the NPT end connector this time
I used a Bitspower 3/8 to 1/4 adapter, and since the thread depths is only 5mm, it seated the o-ring just fine before any binding presented it self (fitting.jpg)
Edit: Not sure where in the world you do your shopping, but the cheapest I found is FRESH WATER SYSTEMS
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (19. Dezember 2023, 17:02)
Dienstag, 19. Dezember 2023, 18:36
I went with model F-40376LN-6 (3/8" F/NPT) ([attach]10581[/attach])
Thank you for this information. I am in the southeast US and also found Fresh Water Systems in a Google search. They do list the -4 version with 0.250” Female NPT LINK. It is out of stock but says More Expected Soon. It costs ~$11 more than the -6 version with 0.375” Female NPT for some reason. I also found it HERE but the -6 and -8 versions seem to be much more common. I wonder if the 0.250” Female NPT fittings obstruct flow rate more than the 0.375” or 0.500” fittings.
I used a Bitspower 3/8 to 1/4 adapter, and since the thread depths is only 5mm, it seated the o-ring just fine before any binding presented it self ([attach]10582[/attach])]
Thanks for the tip about the Bitspower BP-BSWP-C23. May I ask where you bought them? I checked ModMyMods, Performance PCs, Titan Rig, and Frozen CPU for the this fitting. No luck other than Performance PCs, where it does come up in a search but when I click on the item, the product page is not found. I need to make a final decision on which model to get, then I can worry about finding proper adapter fittings. I have found NPT to BSPP adapters but so far they are always the same size on both ends, so if I use an NPT Male to BSPP 0.250" Female, I will have to get the -4 version of the flow meter. I would prefer a nickel-plated brass adapter and wonder if THIS hydraulic hose fitting with 18 threads per inch will work. AFAIK, standard water cooling fittings have 19 threads per inch. I will search McMaster-Carr and Grainger some more. Generally, I find it oddly amusing that we water cooling enthusiasts have to become precision plumbers. :D
Dienstag, 19. Dezember 2023, 22:53
I believe the flow rate is different for the one you linked (0.025 - 0.25 GPM / 0.1 – 1.0 LPM)
It appears there are standard, in-stock units and custom built options. Had I been aware of the 1/4" version (F-40376LN-4) I would have purchased it. Though it is about $15 more at PVC Pipes & Supplies, the difference will almost be made up by not needing adapter fittings... plus less fittings is more.
Performance PCs has the fittings in in BLACK, RED, SILVER, WHITE & probably Black Sparkle (Email sales).
Personally, I would get the F-40376LN-4 unit at PVC Pipe Supplies and not worry about adapters.
You can place the rotameter in a test loop with Bitspower fittings and see if it holds pressure.
I am contemplating getting one myself to play with 8)
Mittwoch, 20. Dezember 2023, 00:55
Oops you are right. Thanks for catching that.
All of the options are Female NPT so I think an adapter fitting is required regardless of which size the NPT fittings are. You have to convert from NPT to BSPP. Are you suggesting that a standard BSPP 0.250" Male fitting may thread far enough into the 0.250" Female NPT fitting for the O-Ring to seal?
Thank you for linking these. The part numbers are different than the part number at the Bitspower link you provided earlier. I see now that the 2 characters to the right of the dash denote the color/finish.
So the Bitspower adapter fittings ARE required. Yes this is probably what I will do. I will probably end up ordering $100 worth of stuff from PPCs because the shipping cost is probably more than the fittings. I usually wait until I have a shopping list long enough to justify the shipping cost before ordering online. I hate paying for shipping. I found the red and white ones on Amazon Japan with free international shipping but they were $23 each. :cursing:
Of course that makes sense because 2 flow meters is more fun than 1 flow meter. :rolleyes: You could also determine if the smaller inlet and outlet fittings reduce the flow rate. Curious – have you compared the flow rate reported by the Blue-White with a High Flow series flow sensor?
Many thanks for all of your help.
Mittwoch, 20. Dezember 2023, 05:05
That is what I did with the Blue-White rotameter I have, Bitspower 3/8" BSPP male directly into the 3/8" NPT female end fitting on the rotameter
If you go with 3/8" end connectors on the rotameter, then yes, you will need the 3/8" to 1/4" adapter
If you go with 1/4" end connectors on the rotameter, you should not need adapters
If it were just the rotameter, perhaps the end connector size could influence flow, but with a full loop, I do not believe it has a noticeable impact. The water blocks will be your primary impedance.
You decide (LPM to the right on the rotameter):
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (20. Dezember 2023, 05:22)
Mittwoch, 20. Dezember 2023, 18:20
That is what I did with the Blue-White rotameter I have, Bitspower 3/8" BSPP male directly into the 3/8" NPT female end fitting on the rotameter.
Now I get it – thanks.
This makes sense.
Looks pretty close to me, with the Blue-White showing a slighting higher value.
Thanks again for helping me with this.
Mittwoch, 27. Dezember 2023, 19:21
Got the Blue-White F400 with the 1/4 NPT ends.
The threaded female ends on the flow meter are slightly beveled at the top of the thread, causing the o-rings to on the G-1/4 fittings to not seat properly.
The standard o-ring supplied with Bitspower fittings look to be 1,5mm thick, so I tried 2,5mm thick o-rings I had laying around, and that seemed to work.
It is an option if the overall height of the flow meter with the adapter fittings is too tall.
2.5mm o-rings: oring1.JPG
Fitting with 2.5mm o-ring: oring2.JPG
Mittwoch, 27. Dezember 2023, 20:39
Thanks for the update, and good to know info about getting a seal with 2.5mm O-Rings. Are those O-Rings made from Buna-N (Nitrile)? Blue-White has options for Viton and EP O-Rings. I am not sure what EP stands for - maybe EPDM? The sticker on the bag in your photo says 11.50 * 2.50. Does that mean the O-Ring is 11.5mm in diameter and the thickness is 2.5mm?
Mittwoch, 27. Dezember 2023, 21:05
Having seen the the bag, you know everything about those o-rings I know, and have not been concerned about the material, as the coolant is not all that corrosive.
Yes, 11.5mm ID & 2.5mm thickness.
EP may be something like Ethylene Propylene or Ethylene Polypropylene.
Donnerstag, 28. Dezember 2023, 00:11
Yes I suspect the material the O-Rings are made of is not very critical in this application.
