• 10.10.2026, 09:24
m1has
New D5 next pumps are noisy.. :( rattling sounds
Dienstag, 26. Dezember 2023, 05:07
Hi, I installed new pumps in my system today. It growls from the first start. What do you think about it?
Link for video https://webshare.cz/#/file/ziF6qzccse/pumpen-mov
Thanks.
neuer Benutzername
Dienstag, 26. Dezember 2023, 11:15
Can´t open your video. I have "Dia Show" :rolleyes:
when i want to see your video, i must pay?
Peter von Frosta
Dienstag, 26. Dezember 2023, 13:17
Hi there,
I have uploaded the Video to youtube: movie
If the OP has something against it - please let me know...
m1has
Dienstag, 26. Dezember 2023, 15:51
Hi there,
Thanks for youtube upload.. what do you think about it? pumps shouldn't make noises like that, i think... :(
Peter von Frosta
Dienstag, 26. Dezember 2023, 17:28
No, that doesn't sound good...
The only strange thing is that it occurs with both pumps. Perhaps some kind of resonance?
Does the "ultitop dual" vibrate when the noise occurs or is there contact with the housing somewhere (the left Pump)?
Maybe there is still air in the cooling medium? Tiny Bubbles in the reservoir with (both) Pump Speed at 100%?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Peter von Frosta« (26. Dezember 2023, 17:33)
m1has
Dienstag, 26. Dezember 2023, 21:32
I tried tilting the computer in different ways to get all the bubbles out. No difference unfortunately.The pumps do not touch anything. I don't feel good about it either. I'll try to check the pumps tomorrow. I just don't know what to look for in pumps.But im afraid i will have to rma the pumps
neuer Benutzername
Dienstag, 26. Dezember 2023, 23:29
maybe try the the pump without the Ultitop Dual outside the pc and check the noise then.
If it is possible...
little loop only pump
m1has
Donnerstag, 28. Dezember 2023, 01:09
Problem is solved.. I removed the rotors on the pumps and put them back after cleaning the ceramic bearing
https://www.youtube.com/watch?v=qIxa8jlbuwM
Donnerstag, 28. Dezember 2023, 20:10
Interesting. I am curious – were both pumps making this noise? When you disassembled the pumps to clean the ceramic bearings was the problem obvious? Did you see foreign material in there? I can see getting 1 pump with an issue but 2 pumps with this problem suggests there may have been a bad run of pumps.
